| I have another problem that you guys might be able to help with, recently i have been getting a knocking sound coming from the front right wheel, im not stupid, its not the wheel bearing and not the wheel itslef! what happens is when i go over rough ground i get a knocking sound like something is loose, i looked a few times and cant find anything. could this be a suspension problem? the bushes or something? someone help me and tell me what to buy that would be great its annoying the hell out of me. cheers
| i am | Re: front wheel knocking noise could be front bushes on the wishbone.my cinq had this before i replaced the front wishbones | ||
| | #3 | ||
| this is where i stand | Re: front wheel knocking noise either worn top mount, or worn ball joint on the suspension arm. both parts are around £30 in parts to replace. the worn ball joint means replacing the whole arm, which is a bit more work than the top mount. you should also replace suspension parts in pairs
__________________ | ||
| | #4 | ||
| Re: front wheel knocking noise that will almost definately be the 'tie bar' - rollbar to suspension had same prob and replaced that and now fixed. costs about £20-£30
__________________ | |||
| Die Hard!!! | The Negotiator | Leisure Lounge | 27 | 24-04-2006 22:20 |
| | dobson2k | Bravo / Brava | 0 | 14-09-2005 12:12 |
| | Louie Bee | Cinquecento / Seicento | 6 | 29-03-2005 01:52 |
| "New X1/9" Front Engine Front Wheel Drive!! | seattlex19 | Lets Talk FIAT | 2 | 28-02-2005 23:27 |
| | wimmy | Bravo / Brava | 12 | 19-07-2004 03:54 |
