peice of ****.........
theres a screw at the top of the pod you can see it from in the window screen right near theback near the dash undo that, then take the 4 screws from below the ignition casing.....
rove the bottom ignition case, then look underneath at both sides and there will be a screw either side (near the rubber flappy bits of the stalks) undo them and remove the top part of the ignition casing, you will then see 2 allenkey style bolts holding the pod in place undo these and the what you need to do is d/c the speedo cable from the back of the pod, and alsothe 3 othe wire connectors
thats the pod off.
then you need to undo the casing which is held by a few screws then it gives you access to the bulbs at the back of the speedo pod.
they are push and twist style bulbs, but the tiny bulbs pull out of their black push and twist bases, they are about 99p for 2 bulbs from halfords or motorwold/parkers
i would post pics if i had some, but i cant be assed to take my speedo pod casing off again as its sprayed up colourcoded and dont want to damage it.
