Firstly if you want a proper induction kit, get the GSR
The GSR kit is a proven winner. But I wanted a project.
And if u can't afford one like me then make your own!
Ingredients:
Air filter, mine is a 60mm 'green' filter from ebay, £15 with p&p
Reducing 90 degree silicone pipe (samco one) 60mm to 51mm, £20
50mm plastic drainage pipe from homebase, 2m for £6, i couldn't find it any shorter!
silicone reducer from ebay ,51mm to 38mm, £10
Breather filter, from local shop, £10
899 cap few £ from ebay, bolts and gasket from phil from here for nothing, cheers !!!!
Before anyone days that I only have one bolt in, yes I know, I've snapped one of the normal long ones in the end and need to get the bit out
Also I've used a breather filter instead of connecting this to the cap, will this cause any long term problems? I've had a long run out and had no problems with it all, no oil spilling or smells.
All in all cost me £50, well, £60 if you include the breather.
It has a nice noise at around 3k and seems to pick up nicer at high and low rpm. Anyway here is some nice pics.
Ingredients:
