Thread Tools
Old 31-03-2006   #1
Engine Control System Failure warning light on
Today whilst driving to work my EOBD light came on. The engine was hesitating alot when attempting to accelerate and when it did accelerate it juddered. This also happened when letting off the accelerator. In the car manual it says contact your local Fiat dealershipo but they are closed so I thought I'd ask the real experts In the manual it describes the possible fault to do with fueling and emissions, I did recently change the fuel tank on my car but that was last week so I thought if I had done something wrong the light would have come on sooner...
Anyhow thanks in advance people,
Fred
RIP 98 Cinq Sporting, K&N, Tricker TB, Mckrich chip
2001 Seicento Sporting Abarth, standrad at the moment
fredjudd is offline Reply With Quote Quote
Old 31-03-2006   #2
I Need Beer
allanhelen's Avatar
allanhelen has donated!
Re: Engine Control System Failure warning light on
Sounds a bit like its missing on a cylinder or two could be one of the coil packs or the crankshaft sensor,
if you have a multimeter it is always worth checking the coil packs, its dead easy to do, the usualy fail on the primary LT side
No FIAT's any more and nothing else sensible either
allanhelen is offline Reply With Quote Quote
Old 01-04-2006   #3
Owner of a 1 off Cinq!
Giggz's Avatar
Giggz has donated!
when mine came on i just put some cat cleaner in and it sorted it.
Giggz is offline Reply With Quote Quote
Old 01-04-2006   #4
When the exact same thing happened on my wifes Renault, found it to be a split vacuum hose, just replaced 8 inches of hose and better than ever. Dont know whether or not we have them on Cinqs !! if so try that.
evoscinq is offline Reply With Quote Quote
Old 02-04-2006   #5
Well, after cleaning the plugs and HT leads the light has gone off. Haahahaa
I love fiats, cheers for the help people.
Old 18-09-2009   #6
Hi all,
I'm a new fiat multipla owner, delighted with the car but having a few problems, mostly sorted but tonight my EOBD light came on. It was bought from a second hand dealer and Ive only had it 4 days so Im gonna let him book it in and deal with it.
However I was wondering if there is something simple I could try in the meantime to save all the hassle of keeping it off road until its fixed.
How long can you run the car with the light on without damage, it certainly seems to be acting normally no other problems but the light itself
Thanks for any advice given
CraigA is offline Reply With Quote Quote
Old 18-09-2009   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Generally the light coming on will put the ecu into safe mode. You will be able to drive, but will not get all the performance.
SPD
Old 30-11-2009   #8
I have the same fault, it only happens in the rain, so i imagine water is getting on to something it shouldnt? the light comes on (icon of an engine) it used to just flash, but the light is on all the time now since coming back home on the motorway last night, the spray from other cars causes it or going trhough a large puddle.
Not sure what to do, but its running really rough. Disconecting the battery reset it?
Regards
Chris
fiat126club is offline Reply With Quote Quote
Old 30-11-2009   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by fiat126club View Post
Regards
Chris
Check the connections on the lower O2 sensor. I am guessing as you have an engine picture its MPi.
SPD
Old 15-12-2009   #10
Hi
My Multipla is suffering a similar problem as the engine warning light has started coming on when the engine is revved and this evening the engine would not restart whilst still hot. It restarted after 30 minutes and was fine being driven very gently, but the warning light came on if revved a little & once again will not start.
Any ideas appreciated.
saligari is offline Reply With Quote Quote
Old 15-12-2009   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by saligari View Post
Hi
Multipla is whole different kettle of fish to a cento, but basic principles apply.
I would suggest a temperature sensor is giving wrong information.
I would als expect Multipla to be OBD compliant, so an autospark with Examiner software could test the sensors for you.
SPD
Thread Tools
(T) Engine Management Warning Light Madness! Power Steering light Insanity! Moneypenny Punto (Mk2/2b) 11 12-02-2010 15:10
(T) Bulb Failure Warning light on dash Brad Stilo 35 28-04-2009 09:54
(T) Knock Sensor? arseofbox Bravo / Brava 13 29-03-2006 18:24
(T) Sei - Engine warning Light PickeringDM Cinquecento / Seicento 1 14-06-2005 00:13
(T) oil sensor failure / engine disaster Heather's Stilo Stilo 24 07-05-2005 00:16
