The FIAT Forum
Old 18-02-2006   #1
Italian Coke Can's Avatar
Trader Rating: (0)
Sil rust - How bad is bad?
After successfully changing the engine mount I found this lovely patch of rust. How bad is bad and what’s the possible solutions to this?
All I’ve managed to find so far is
Corrosion
A vehicle can fail with respect to corrosion for:
* excessive corrosion in a 'prescribed area' — within 30 cms of certain safety related components, e.g. brakes, steering, suspension, seat belt mountings etc.
* excessive corrosion not in a 'prescribed area', but which is likely to adversely affect the vehicle's brakes or steering. 'Excessive corrosion' can mean a hole or a significantly weakened structure.
Italian Coke Can is offline
Old 18-02-2006   #2
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: Sil rust - How bad is bad?
That is not bad at all, mine was like shredded wheat for about 3 inches in each direction. A patch will suffice, remember to weld all round the patch, no stitches allowed.
D
rallycinq is online now
Old 18-02-2006   #3
Trader Rating: (0)
More details on patches? Something i can buy or is it a case of making? My mate is good with a welder, but i'm not sure if i trust him with this.....
Old 18-02-2006   #4
Trader Rating: (0)
Oh, would this be a MOT fail?
Old 18-02-2006   #5
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
chaos has donated! United Kingdom
Probably
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
Old 18-02-2006   #6
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
  1. Get a piece of metal plate the right size
  2. Hammer said piece of metal to match any contours
  3. Weld it in, leaving no gaps, i.e. full seam weld
HTH
chaos is offline
Old 18-02-2006   #7
Trader Rating: (0)
HTH
Thought there might of been a more technical method
Old 18-02-2006   #8
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
I forgot to say derust the sills before welding
chaos is offline
Old 18-02-2006   #9
rallycinq's Avatar
Trader Rating: (1)
I would prpbably start with,
Grind hole back to good metal,
then,
Make a patch etc.
then
Grind down welds and paint
D
Old 19-02-2006   #10
Principality Retained :)
Trader Rating: (3)
arseofbox has donated! United Kingdom
It was reasons like this that my 899cc is lying in my garage being stripped of anything saleable...
Cost of repair was silly and car was dirt cheap. That and I had an idea...
arseofbox is offline
Old 19-02-2006   #11
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
And I wonder what that would be Tom
chaos is offline
Old 19-02-2006   #12
T.E.D.
Trader Rating: (1)
T.E.D. Jordan has donated! United Kingdom
Not really, you can buy a full sill but thats laughably stupid. What has been suggested is the best method and basically the only one. That woudlnt fail an MOT as its isolated enough at the inute, but when it spreads upwards and worse, further under, it compromises strength even more so. Basically cut out the rust, and while its got the hole in the sill that you have removed, spray some preservative down the sill if possible, like waxoyl or even old engine oil also de-rust the surrounding area. Tidy the edges and weld a plate it, then smooth it back and when cool smoth over with primer if you wish to. If not then just paitn over with preservative paint - good as new (lol nearly anyway)
Total Engineering Developments
T.E.D. Jordan is offline
Old 20-02-2006   #13
Trader Rating: (0)
Excellent. I'll get onto it soonish. Depends how much other stuff to get it through it's MOT.
95 Tipo 1.6 cuts out, dies, bad idle/starting xenium Tipo 12 06-07-2005 13:21
(G) Bad noise Luke Uno 16 14-03-2005 01:10
Bad reputation....???? chrisunoman Site Ideas 2 25-12-2004 16:33
(T) Windows misting really bad pcoltas Punto 9 05-12-2004 03:03
