Lamps by Post - For all your lighting needs
Thread Tools
Old 07-01-2006   #1
Help how much gearbox oil seicento 899
Hi
Got a leaky inner cv joint on an 899cc seicento sx 2001 model. I am going to drain the gearbox oil and refill but cant find a reference as to how much oil is needed. Any help would be great.
Also, where is the refill plug for the gearbox?
thanks in advance
Cy
cycento is offline Reply With Quote Quote
Old 07-01-2006   #2
Forum moderator
Helz's Avatar
Trader Rating: 3
Helz has donated!
Re: Help how much gearbox oil seicento 899
How weird, I just asked the same thing via text message and someone kind looked it up for me in Haynes. 2.4l (assuming it is similar/ the same as in a cinq) and you need 8mm and 12mm allen keys for bottom and top plugs respectively (again assuming same as cinq). If anyone could come up with a definitive answer as to if they are the same then that would be better than my guesswork which has been known to be wrong
http://www.fiatforum.com/cinquecento-seicento/50457-squealing.html
Helz is offline Reply With Quote Quote
Old 07-01-2006   #3
Ok thanks thats great. I would assume they are the same but a friend of mine is a mechanic and told me to remove the filler plug and fill the box until the level is just reaching the lower edge of the hole so either way i guess i'll find out if the cinq and sei are the same.
Certainly the engine is almost identical in my wifes seicento compared to the old cinq it has replaced.
We had some squealing too but ours was a result of a leaky rocker gasket spraying oil onto the alternator belt. Its while i was changing the rocker gasket and belt that i noticed the leaky boot. Have you ever tried using one of those universal split cv boot kits? Thats what i bought because the fiat dealer was closed and none of the motorfactor places had the right boot.
Old 07-01-2006   #4
Principality Retained :)
Trader Rating: 3
arseofbox has donated!
Quote Originally Posted by Helz
Did you SMS somebody else then too? I was just wrenching the NSR spring off when your message came through...I didnt look it up, that was a purely off the cuff number based on previous experience .
Drain plugs are the same for S/Sx and Sporting . 12mm drain, and 8mm fill.
arseofbox is offline Reply With Quote Quote
Old 07-01-2006   #5
arc
this is where i stand
arc has donated!
something i learnt when the box was out of my car too, gearbox oil absoloutly stinks!
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 07-01-2006   #6
yellasei has donated!
dont forget oil is 80w non-hypoid, most from shops is hypoid.
yellasei is offline Reply With Quote Quote
Old 07-01-2006   #7
Trader Rating: 3
Whats the difference between hypoid and non-hypoid oils? other than the use of non-?
Old 07-01-2006   #8
Quote Originally Posted by pandy
oops! got it wrong, its 80w for sporting and 90w for s+sx, quantity for s+sx is 2.4 litres or to bottom of threads.
Old 08-01-2006   #9
Forum moderator
Helz's Avatar
Trader Rating: 3
Helz has donated!
I did Tom, my phone was playing up and showed texts as not being sent when they were (be glad to get my usual one back) so I sent one to Pete several times, didn't think it had sent, then sent one to you, only to get a reply from Pete as well
I didn't realise there were different types of gear oil, the shop that sold me the keys just had one on the shelf that said 'suitable for manual transmission cars' so I just picked that up. It sounds very thick anyway.
Old 08-01-2006   #10
Ok just finished the job.
Universal split cv joints are a nightmare. I am going to order a proper fiat inner cv ang get the job done properly. I dont have much faith that the joint will last for long.
One thing i did notice is that both the drainplug and filler plug were 12mm
Thanks for all the imput guys
Cy ;-)
Old 08-01-2006   #11
Forum moderator
Helz's Avatar
Trader Rating: 3
Helz has donated!
I've just been under to do mine as well but can't get the filler cap undone so I have a mate with muscles and a big ratchet coming round tomorrow to see if he can shift it Can't find a split but there's definitely a leak down there somewhere, it's black and wet and yucky, will just fill up for now and consider sending it to the garage for a better look There also seem to be some random bolts missing so it looks like other work has been done down there at some point and they had bits left over afterwards
Old 08-01-2006   #12
arc
arc has donated!
if its a bit stuck, spray a bit of pentrating oil on the drain plug - see if that'll free it up a bit for tomorrow.
On the 899's the inner CV joints are lubed by the gearbox oil, if one of the rubber CV boots have split - it'd leak gearbox oil. Might wanna check they're intact before replacing the gearbox oil. I'm not sure if you can replace them without having to drain the box.
Old 08-01-2006   #13
Thats right arc, you cant replace the boot without draining almost all of the gearbox oil.
My drain plug was stuck too but a quick spray with plusgas and ten minutes to let it soak in. I then got my biggest ratchet and it came off no problems.
Old 08-01-2006   #14
Also, if the oils black isnt it more likely to be engine oil, like from a leaky sump or rocker gasket?
Old 08-01-2006   #15
Forum moderator
Helz's Avatar
Trader Rating: 3
Helz has donated!
Done that already arc (and left it half an hour and tried again myself), thanks for the thought though What you say about draining is also why I'm just topping up for now (if mate can get it undone) and not replacing as I had originally planned
Thread Tools
(T) HELP!! Re-filling Seicento Sporting Gearbox milkshake Cinquecento / Seicento 5 06-12-2005 18:01
(T) Oh dear, gearbox oil leaks Blondeinapunto Punto (Mk2/2b) 4 04-07-2005 17:19
Synthetic Oil - Not always what it seems! oilman Lets Talk FIAT 10 04-02-2005 00:36
(G) Gearbox oil top up. Blueflag Ducato 1 27-03-2004 18:06
(G) Which gearbox oil belgrade_punto Punto (Mk2/2b) 0 17-03-2004 04:10
