Hi I notice my new Cinq.Sporting had a timing belt change by an utter moron of a gorilla/mechanic !!!!!!!(obviously the elderly lady owner was not too careful in her choice!)Amongst the fallout from his work was:
1 Didnt replace TB plastic shroud/cover
2 Made a mess of replacing underbody/ wheel arch liners
3 Lost retaining clip at front of air intake
4 Temp gauge not working as he didnt notice he had loosened sensor electric spade connector!
5 Damaged piping for rear washer under bottle with result neither washer works!!!
6 Put every possible loom/wire/hose/pipe back as if blindfolded ,some even being crushed under screwed/bolted down components.Absolute unbelievable mess!!!
7 Warm air pipe bracket/connector to manifold lost?
Anyway he seems to have ripped out much of the rear washer piping from the front so while Ive bunged it up and at least have a front washer can anyone tell me the general route the pipe takes from front to rear.Is it meant to run beside front washer as far as windscreen?Thanks!And choose your mechanic carefully!!!!
