- Jun 21, 2004
- 805
- 207
Ok guys, just finished off the rear discs on the cinq (well my mate jon did)
Started with uno turbo hubs, calipers, caliper mounts, discs and pads.
Everything was a straight swap, a diff brake line needed making up to connect to the caliper either side.
Also the handbrake cable needed modifing as it wasnt long enough on one side. The handbrake cable doesnt appear to be long enough if fitted through the original brackets going under the car so it has to be trailed under the tank (if that makes sense)
the handbrake holds rock solid and braking seems to be more efficent.
will get pics up asap
