project-cinqy
Member
I know people have posted about this before, but I've read the threads and knowing posted how they fixed it!! so here we go!
It ticks over fine, but if you rev it and let it drop it drops to quick and almost stalls. On the move it sometimes stalls when you take your foot off the accelerator and put the clutch in, usually when changing gear before a corner.
I'm not sure quite what could be the problem, my thoughts are,
Lambda,
Throttle position sensor,
Injector,
crank tdc sensor.
The map sensor is fine, the revs rise when you blow down the tube, and the pipe is clear.
Any ideas?
Jon+Em
Lambda,
Injector,
crank tdc sensor.
Any ideas?
Jon+Em
