Thread Tools
Old 1 Week Ago   #1
Exhaust Flexi Section
I had to take my 2002 1108cc Seicento on a long trip and while away from home I had to have the back section of the exhaust replaced at a garage. They said that the flexi bit could do with replacing sooner rather than later. I had a look at it, and yes it had surface rust, but it wasn't ready for replacing yet, in my opinion. So, I let them just fix the back section, and thought I'd do the flexi bit when I got home.
The back end of the exhaust that the garage ordered and put on has two "boxes". When I had a look at the Haynes manual, searched for online parts, and also had a good read of previous threads on here, I am confused about what exactly I need to buy for this "flexi bit". It seems that this is complicated as the O/D and sections can vary. also, some of the links on the threads are old and/or not working.
So, can someone advise me please on how to identify which bit I need? Also, will this involve welding, or is it clamped on? Plus, I've got ramps and axle stands, but no pit, and is it just less faff to take it to a garage and let them sort it out? I'd rather do the job myself though.
Thanks,
Andrew
CasLad is offline Reply With Quote Quote
Old 1 Week Ago   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Exhaust Flexi Section
Yours should be MPi which means you have the manicat.
The section after the manicat contains the flexi and is clamp on.
D
Old 1 Week Ago   #3
I have to do this job soon. I ordered the longest pipe as there are 4 options. I might be able to cut it shorter if necessary. I'm hoping it will fit without too much faffing!!!
Otherwise I'll be cycling to work...
purf is offline Reply With Quote Quote
Old 1 Week Ago   #4
Trader Rating: 1
cc1 has donated!
There are 2 versions with reference to pipe diameter so check yours before ordering.
cc1 is offline Reply With Quote Quote
Thread Tools
(G) Exhaust flexi pipe repair section tonyn Panda 1 01-05-2016 19:32
(T) Exhaust Flexi Section GhostWKD Cinquecento / Seicento 16 02-05-2007 12:05
(T) Flexi Section Alternatives? GhostWKD Cinquecento / Seicento 10 22-02-2007 19:50
(T) cinq exhaust flexi section. mase Cinquecento / Seicento 20 30-07-2005 23:15
