General Boot drain plug?
CasLad
In the boot of my Seicento 1108 (2002), when the spare wheel is removed, there is a steel/iron circular detachable insert. It seems to be there as a drain plug.
I expect it is common for this to rust. Anyway, mine has rusted. The plug is kaput, but the surroundings are saveable I think, so I want to get the job done.
I have searched the internet to see whether these drain plugs are available to buy, but I can't find anything, perhaps because I am not typing in its correct name.
Is it possible to buy these drain plugs? If so, what exactly are they called? Or is it a scrapyard job or a case of fabricating my own? It seems to me that a rubber plug would be as good if not better, if I could find something of the right diamater.
Thanks for any help.
Andrew
I would agree that it's easier to fit a drain plug. It's surprising there isn't one.
Measure the hole and look on Ebay for rubber grommets
http://www.ebay.co.uk/itm/Blanking-Grommets-Rubber-Closed-Grommet-Blind-Hole-6mm-9mm-12mm-16mm-20mm-/271140812144?var=&hash=item3f21407570:m:m7cwLnFPglEIU2uu8vAfEvw
A drain plug is simply a rubber grommet ... a 'blind' rubber grommet.
If push comes to shove and you need a plate welded over the rusted area, just drill a hole in it and get a grommet to plug the hole.
It's an easy fix .. you could use a tube of bathroom sealant - silicon - to squirt around the area to fill in ... (go to Poundland..) or even just use a rubber patch glued into place. Anything that can be removed to allow water to drain out will do the trick.
On my first Cinq this was rusty so I used a baked bean can lid with sealant. No joke...
I would have thought the hole was more likely part of manufacturing rather than a drainage thing.
Thanks for both these replies. That baked bean can is a good idea! Excellent, thanks.
Andrew
I left the hole open and rivetted a plastic flap, about 3 inches square, under the floor directly in front of it.
This allows water to flow out the back when moving but does not allow spray up into the boot space.
D
