biffy elliot
- Mar 29, 2011
- 9
- 3
My Seicento has started to run rich, I have checked the temp sender in the inlet manifold,which is working ok. The Lambda sensor heater checks out ok, but I have no batt voltage from the vehicle to power it.
Where does the power come from to energize the heater?
Would a faulty supply make it run rich? or is there two faults?
It's a 1999, 1.1lt sporting with sp injection and only 1 Lambda sensor.
It drives ok ish, but is lumpy at idle.
P.S I have changed the plugs (old ones very sooty) run with no air filter, disconnected the eng breather and checked for any obvious leaks.
Thanks for any help
Steve
Thanks for any help
Steve
