F fstroi7 New member Joined Jul 24, 2017 Messages 3 Points 1 Jul 24, 2017 #1 I want to ask if ECU MAGNETI MARELLI IAW6F.SF it is compatible with Fiat Cinquecento 899cc 1993 no immobilizer.
OP OP F fstroi7 New member Joined Jul 24, 2017 Messages 3 Points 1 Jul 24, 2017 #2 fstroi7 said: I want to ask if ECU MAGNETI MARELLI IAW6F.SF it is compatible with Fiat Cinquecento 899cc 1993 no immobilizer. Click to expand... Factory my Cinquecento ECU is IAW16F.EO. Engine code 1170 A1.046.
David C Patron member Joined Mar 29, 2005 Messages 1,787 Points 399 Location London Jul 24, 2017 #3 The only info I've found is a IAW6F.SF on a Seat Marbella 903 carb engine (basically a Panda). So it may not control the fuel injection.
OP OP F fstroi7 New member Joined Jul 24, 2017 Messages 3 Points 1 Jul 25, 2017 #4 I did a test. The problem is that, the SEAT Marbella has a mechanical gasoline pump. SEAT Marbella ECU has no mandate for a gasoline electric pump that has it Fiat Cinquecento.
