Technical dodgy steering after spring change
jonjg
ive recently changed the rear bushes on my cinq to poly bushes. i also changed both the front springs.
occasionally the steering randomly dives to the left and there is randomly oversteer while going round a left hand bend.
do you think the top mounts are playing up, i havent sat the springs properly or what?
hoping to sort it tomorrow.
any help would be great. ive changed springs loads of times, never had this issue.
thanks.
hi there, i have had this problem before, as new springs are more stronger than the old ones, the car will sit up higher than the old ones, i would get the tracking done on the car, that will help with the steering, please note that you will need the 4 wheel tracking, this will make sure that the car is set up correctly.
hi there, were the top mounts changed at the same time, as can sometimes become stiff especially with new taught springs, sorry cant be of much more help :)
hello. no i didnt change the top mounts at the same time,kept the originals.do you think i should change them? tracking is ok, drives fine in a straight line, no pulling or slowly veering.
i cant remember tbh, il take it apart thiseve and have a look. im guessing they should do?
ok. i check that later.
im pretty sure i didnt get them mixed up when changing the springs but is there any way to make sure?
