General Wiring uno wiper motor in a cinq
DIDCOTT
Member
Hi.
I have fitted a front wiper motor from an uno to my cinq but it hasn't got a connector on the end.
Could anyone please tell me which wires to join to which to enable it to work
IMG_4570.JPGIMG_4571.JPG.
Thanks.
I'm guessing black is the earth and the 2 tone cables are for the intermittent and full wiper settings what would the other blue one do? And where would they go on the cinq plug? Thanks
I did this once and probably just tried touching the wires together until I figured it out... I don't remember doing any damage...
I used a couple of countersunk m6 bolts through the grill in the windscreen cowl on a Cinq. Im sure there's a better way though. How have you fitted yours?
Thanks purf I will tinker tomorrow
Just can't get my head round what wire goes where.
Same as you suggest.
The bolt holes line up perfectly with the slots in the scuttle panel so I had used some small bolts with nylon washers and put a couple of black number plate caps over the bolt heads to finish it off.
Did yours work on one speed only for both stalk settings or did you manage to get it to work on two different speeds?
Thanks for replying
I think it worked on two speeds but no intermittent of course as with all centos... Hard to remember now!
Oh look what I found in my gallery dated 2008! I cant recall if it was a Panda or Uno motor now? is it the same as yours?
Not sure how helpful the photo is for wiring as i think the wires are extended from the stock motor position... I'm sure I improved the yellow electrical tape after the photo was taken... ;)
