Beefymilly92
- Jul 1, 2017
- 10
- 1
Hi everyone, well I just passed my test yesterday, (had the cinq for a few months before hand)
When I got it, I changed the front brake disc's, pads, coolant hoses, coolant, oil and filter, air filter, oil breather (pipe that goes from rocker cover to air box) and a new battery.
It went to the garage and had a new handbrake cable, slave cylinders, new centre exhaust....
Anyway its always been a bit stuttery at low revs (as in ideling) you burp the throttle and as the revs die it felt as if it would stall before it picked up again
My local mechanic said it could be the injector, give it a good clean and try that
A few weeks later I did , (it was almost black inside, got I cleaned up and made a new gasket, fitted it and left for a bit due to other commitments, went back to it a week or so later and now it barely idles, you turn the key start it and it will rev a little (as in choke) then die unless you lightly burp the throttle, if you put your foot down it just dies....
I got it insured today and went a mile down the road, (it was f**king terrifyingly!!!!) Kangaroo comes to mind, you try to accelerate after you let the clutch out and it tries to die, lift the throttle lightly and it sort of picks up...then tries to die...
HELP
HELP
