Hi guys.
I haven't needed your assistance for some time as the car has ran like a peach.
But i have a problem.
Last night while tootling around taking my mam shopping i lost power.
I could coax the accelerator back to life and the car would lurch forward and the revs would die again.
When i got home i had a quick look under the bonnet for anything obvious wrong but no all looked good.
So i drooped off the positive connector from the battery and left it off 30 mins or so.
Reconnected and plugged my cheap scanner in to read the codes, but no codes were stored?.
Took it out for a bit of a blast and all seemed well. it idles ok but does splutter a bit with the first tap on the gas.
Anyway drove to work and back today and the engine light came on.
Good i thought, i can pull some codes now.
But when plugged in it doesn't even recognise the engine light is on.
Its had a new ECU in its life, could that be the issue or am i missing something, fuse blown etc ?.
Thanks.
Thanks.
