Jumbo98
Hi all, so i very recently bought a seicento 1.1 sporting T reg, i have had a number of issues i have fixed and am still yet to address, but this thread is based solely on the driveshaft. i have found it very tricky to find any information about these cars, and have relied a lot on reading the threads on the forum which have been very helpful. i am hoping that you guys will be able to help me out with my current issue.
So after having a look around the car, i noticed a small amount of oil dripping down the side and bottom of the sump, at first i suspected it might be a cracked sump. after looking further, i found out that i had a split outer cv boot on the passenger side. i believe this has been driven around like this for a good few weeks which has made quite a mess around the wheel and the suspension etc. i hope it hasn't done any damage to the CV joint itself! Whilst looking around and cleaning all of the greasy mess up, i also noticed that there was some grease/gunk (not a great deal) sprayed out from around the inner boot as well, leading me to believe that i had a split inner boot as well. after thoroughly cleaning around the inner boot, I checked all around the inner boot for any splits but i could not feel or see any, i was quite confused by this as i am not sure why there is grease sprayed up around it as there would be with a split boot
Anyway whilst i had the car jacked up, i decided to have a look on the drivers side drive shaft as well, upon which i found that there was some OIL but NO GREASE around the inner boot. I believe this is where the oil dripping down the side of the sump is coming from, but i am unsure of what the cause of this is, could there be a seal gone where the driveshaft joins to the transmission causing oil to seep out? what would this involve to replace?
Does anyone know what the best steps to take are? whats the easiest way to replace the boot on the passenger side? do i replace the inner boot aswell whilst im at it? would it be worth just buying a whole new passenger side driveshaft? how do i fix the oil leek on the drivers side inner CV joint?
Also does anyone know any good places to source parts from? i am really struggling to find the correct parts for my car. A lot of searches i do come up with cinquecento parts and i know they are very similar but will these parts (driveshaft etc.) definitely fit my seicento?
any help will be much appreciated, thanks
