So we gets round to this job today. 8 hours and no real drama but i have a slight whine. I think its not that bad and sure my Stilo had a whine also. Anyone else left with a whine after changing belt and did you bother slackening off the tensioner?
Check the tension... it could be too tight. If it is, it will put a load on the water pump and you might get a leak soon.
How old is the water pump? Cinq/Sei pumps seem to last okay but I'd change it every second cam-belt at least just to avoid problems.
Ralf S.
Never changed the pump Ralf. Reason being the car is just got 37k on the clock and my reckoning is if anything is wants changed it would just be the belt due to age rather than wear. The old belt did look good. The new belt came with a new tensioner so thats been changed. Wife is away with the car later today so ill hang back and see if she thinks its loud as she drives it more than me so should be able to tell better.
From memory, I think the Allen key is 12mm (although I also have a 10mm one knocking about... ) If doesn't have any gasket or o-ring.
Ralf S.
Ah good one cheers Ralf. I have a 12mm Allen
BTW how much oil is in these things (1.1) with a filter change. Did i read that it was 3.5lt was was that a daft dream i had?
