General Assistance
General Assistance
ryanc134
Assistance needed mid rpm around 3000/4000 got some hesitation any ideas???
Hello mate, I got mine too doing that. What you should look for is maf sensor, vacuum pipes, take a look at the seals in the injector. Done all this and the car "seemed" better. Then I found out that the I had a fu**** up spark plug port which was loosing compression from the piston. Best of luck for you.
