so when you turn ignition on with the pipes off the pump, you can hear it prime but nothing comes out??
If so then almost certainly hte pump, although do take the sender out and check inside the bottom for debris and that the filter bag is on there.. If the pumps clogged its a gonna but you don't want to put another in and it immediately get blocked again.
