Technical Akward water problem in a Cinq
agreed, you need to sort a bleed out for that pipe.. bear in mind the bleed screw on the rad only bleeds the rad itself, its much lower than alot of the water channels in the engine and head, that bleed you have bypassed is on the heater matrix line cause thats the highest part of the system.
Would have been better to pull of the sound deadening and taken the pipes off at the heater matrix itself and joined them together and then you could still bleed - whether thats still possible depends on if you cut the pipes..
Worst case you can just buy something like this http://www.carbuildersolutions.com/uk/black-nylon-16mm-joiner-with-bleed - put it between the 2 pipes you have joined together. But you need to get the bleeder as high as possible - you may need to extend the pipes so you can have the bleeder up at least as high as the original one. ;)
Do this before or the same time as the head gasket ;)
Leak wise, you will just have to search for it to be sure... could try the old dust talc around where it leaks so it leaves trails in the powder. But sounds like its gonna be the metal pipe, its seal or the core plug.
rallycinq I had a spare engine head from a uno, I send it to be ported and sorted out to replace the current one. But right now I have to find out the problem with engine cooling system. That's getting quite hard.
Where's the core plug? I'm portuguese, and the names of the parts are different so its like I don't know anything. Sorry in advance.
core plugs are the little disc type things used to seal the holes from machining the block, there are several on the block but there is a big one right near the water pump
circled in yellow
circled in yellow
Oh .. Thanks, I know now.
So, new update.
- Sorted the leak, and guess what? It was from the thermostat. Yes, it was deformed due to the heat, and wouldn't seal, so I bought a new one, put a new bleed valve, and voila, new.
- New problem I found was that a cilinder is loosing compression from the spark plug.
