- Oct 24, 2006
- 619
- 346
2001 Schumacher
The immobiliser is stopping the car from starting (so says the garage). It turns over but won't fire up. The previous battery got very flat and was replaced with a new one, It's had this problem since the new battery was fitted
I swapped the ECU and immobiliser like for like from a similar car but still it didn't start. I disconnected the battery, replaced the ECU, unplugged the immobiliser and plugged the new one in. I let the aerial part hang and taped the new key to it. I used the original key to turn the ignition on. I then reconnected the battery
So with this it should be using the new key to tell the immobiliser to start the car, right?
I tried it with another spare set (ecu, immobiliser, key) but still nothing
I took it to a garage who tell me the immobiliser is where the problem is
I would have thought replacing the components in the system would solve it
It's still with the garage who are trying to consult an auto electrician, but if they can't solve it, what else could i try?
The car is 80 miles away so i need some good ideas before i can go over there
