1.4 16V on P85 IAW18F ecu running lean, please help!!!
To all Fiat owners,
I am asking for a hint/advice/solution for the following problem:
Engine: 1.4 16v swapped on Cinque with 1.2 16V P85 IAW18F ECU
After I open the throttle, the car is hesitating and running lean(checked that with Innovate wideband) for 2 seconds then it flies to redline. I tried to disconnect the Lambda, to erase ecu learnings, bigger injectors, bigger fuel pressure, changing the ecu, none of these helped.
I saw a lot of these swaps going pretty well so I dont want to upgrade to Megasquirt yet, just looking a cheaper solution.
I am willing to buy the map pack or a map for this ecu if anybody has one.
Thank you all in advance for your help!
Iustin
To all Fiat owners,
Iustin
