- Nov 23, 2012
- 53
- 25
Hi ive been on forum on and off over the years panda classics mainly had a few of them . I picked up a high miler 145000 2003 sei sporting which was in use by same owner from new until just before christmas. Ive gone over car and it seems remarkably good condition apart from a constant gurgling noise from around front drivers side. Coolant was low so i refilled and had the bleed valve open near front drivers head lamp all bled well heater works perfect and seemed like happy days. Then the noise returned and i popped the oil fill plug and theres a tiny bit of froth on the oil . Ive put that down to it being sat in sub zero temps and wet for the past month and not been driven . There is no oil in coolant heater works well fan kicks in but my question is how do i stop the gurgling noise . I couldnt see any other bleed valves just the one. And any seasoned sei owners maybe able to advise on oil froth is it a obvious sign of chg faolure on this engine god only knows when last oil change was . Any help appreciated. Thanjs.
