Hi everyone I wondered if anyone could please help me with my exploding car?
So I've got a 2001 seicento sporting which was great up until I didn't use it for about 5 weeks straight because I had a works van to drive about in, when I came to use it again I did about 10 miles on the way to work and the red temperature warning light came on the dash but it got me to work then on the way home it came on again but with in seconds of me noticing it a black rubber hose under the bonnet exploded (4 way water/cooling pipe the small fat bit that runs in near the bottom of the engine) I changed the damaged section and filled the coolant and water back up but then I noticed underneath the engine towards the back on the passenger side dripping water out (with the ignition off) a few people have said it could be the water pump but from what I can work out the pump is on the other side of the engine to where its dripping from and also the engine is off and it still drips water
