Metalguru3
Member
Hi
Just had a problem with mine with idle speed anything between 900 and 2500 and loads of popping on exhaust on overrun.
Checked all the usual suspects but everything ok, OBD showing no faults.
Turned out to be a split or battery acid corrosion in the inlet manifold where the vacuum pipe pushes onto it next to battery)
Quick blob of black silicon and alls well again.
Though id post this in case anybody else gets the same symptoms
