More brake problems.
A few weeks ago I had the rear brakes bind and over heat.
The hand brake cable was the problem. I also took the opportunity to clean up, new shoes and re-grease where needed. Problem fixed.
Last night the car had 4 people in it and I drove to get some take out. The car was driven at 30 mph on local roads.
On the way back the brakes started to smell and when I tried to stop the car the brake pedal went straight to the floor. I tried them again and had just enough brake to stop the car. I drove a short distance to find a safe parking place and tried the brakes another 4 or 5 times and still the pedal went to the floor with no brakes.
I got out the car and felt for heat from the rear wheels and they were smoking hot but so were the front ones this time. They were hot enough that I couldn't keep my hand on the wheels.
I left the car until all 4 wheels had cooled down enough for me to touch them and re-tested the brakes again and they were back to normal. Firm not spongy. I drove it around the block and the brakes were back to normal.
I parked the car up for a couple of hours and tested the brakes again and all was fine.
I drove back home with no brake problems. I tested them this morning and still normal.
What would cause this dangerous fault?
