Metalguru3
Member
The 2 flared ends on that length of pipe were what is probably called op 1 on your flaring kit. Ask for the metric tube nuts with the leading edge ( first couple of mm on the nut is unthreaded)
Op 2 may also be used on the car, but not sure (you will need to do an op1 followed by an op 2 on your tool)
Easiest way is get a bit of brake pipe from a motor factors pipe and have a go - youll soon see what you need to do.
Best tool is the sykes pickavant vice held model, so easy to use and very little physical effort required.
