Metalguru3
Member
hope ive read your reply correct as I dont want to teach granny etc etc...
its those 2 large washers in the middle of each shoe - they sit on top of a spring loaded mechanism which allows the shoes to move out so far then return just enough to maintain a pedal. If you force the mechanism with a screwdriver (only a bit a time) you can get the shoes to sit in a position nearer to the drum so you don't have too much pedal travel. Make sure handbrake cable is slack before doing this then adjust cable only when you are happy. Do with care though or you're back to an overheating issue. Probably not Fiat advice but I've always done it and it works for me.
