ZhackZhirack
- Oct 3, 2016
- 70
- 16
Hi.
Recently acquired cinq sporting (1.1) that hasn't been used for a long long time. No MOT history for 10+ years, even though it has been in this country since it was bought as new (only 69kkm on clock).
Only issue is that ours is stuttering (especially lower revs), doesn't want to rev that well and there is a bad loss of power.
So far we replaced plugs, leads, air filter, fuel filter and pump. Have done ECU reset several times. Lambda sensor was between 0.2 and 0.8V. Timing belt marks seem to line up. Engine light is off. Brakes are not engaged, clutch not slipping. All cylinders seem to be firing.
Nearby garage also checked for vacuum leaks and cleaned out intake - all seems good.
Noticed yesterday that if you start the engine then it feels really good for 3-5 seconds. Barely any stuttering and accelerates really well. But after those 5 seconds half of the horses leave the engine and it starts stuttering again.
Loss of power is so bad that acceleration from 0 to 100km/h is 25-35 seconds and top speed in 5th gear is around 100-110km/h.
Any ideas appreciated
