Technical RPM gauge not working in a seicento sporting 1.1
arranbl
HI, could anyone help me my RPM gauge is not working? It could be fuse but i don't know where it is located or if the one fuse is for the full instrument panel. TIA:):eek::)
Should be fuse F22 but this also supplies instrument panel, indicators, sound system and switch lights
Also check for continuity between ECU pin 9 and rev counter pin 4
rev counter earth is pin 3
Pin 2 is for rev counter illumination
The ECU gets its signal from the crank sensor via pins 11 and 28 at the ECU plug
