i will use the crappy ditch finders over the winter
Surely you will be fitting your winter tyres come November..
D
D
Just out of curiousity, what ARE tour current tires? As long as you do not have traction problems (as in: problems to get the power on the track out of corners), I do not think bodyroll is your biggest concern, but should try good tires first.
I was under the impression that slicks will make the body roll worse unless you are running much harder springs
