Ian S
Hi all,
My Cinquecento Sporting, 1108cc, 1998, recently started this fault. I did a bit of boards searching but didn't find anything conclusive, so I thought I'd ask .
It's single point injection but has the GSR inlet and cone filter. Last year I had to change the head gasket and cleaned the breather filter blocked with 'mayo', had the head skimmed. Fitted the 866 cam and shimmed it very well. It ran very smoothly after all that.
Would the ECU be too early, 1998, to have the fault code thing?
It still starts OK from cold but is now rough / missing on idle and low speed, with light flashing instead of steady, and staying on. Those states would continue until I'd driven a mile or two, the roughness then going smooth and the light going off.
Now it lasts longer and is cutting badly at speed on the dual carriadgeway. A bit similar in feel to the rev limiter, or whatever goes on there at about 7000rpm.
The boards suggested:
MAP,
Water temp,
Lambda,
Injector,
Crank position sensor.
(Throttle position sensor)?
(Coil Pack)?
The fault would seem to be affected by engine temperature or/and runnung time.
Water temp goes up a bit, but probably not much in only 1 mile.
MAP unit itself could heat.
Air temp sensor in the throttle body?
Crank position istelf could heat.
Lambda does heat. Is that input ignored by the ECU until water temp is up? Or timed delay? Or measuring straight away? Some delay as has to heat up to work?
In the last 2000 miles or so I fitted new MAP and new water temp sensors.
I measured the air temp sensor and it's Ohms were within the stated limits.
Lambda is about 6000 miles, or less. IS the NGK NTK OZA527-E19 (0296).
AFAIK, the crank posn sensor is the original.
Thanks.
MAP,
Water temp,
Lambda,
Injector,
(Coil Pack)?
Thanks.
