General Front screen wash pump advice needed.
DIDCOTT
Member
Hi all. My Cinq has it's mot next week and whilst checking over things I have noticed that the front screen wash pump is not working.
I have removed and tested the pump and it works well. I have cleaned the connectors and plug and checked the fuse and all seems ok.
I was going to remove the stalk next to see if there's anything obvious there to cause this. Has anyone else had this issue. ? The front and rear hoses are swapped around for now so that I can at least clean the screen. Thanks.
Thanks for the replies. I will try that and if still no joy I will swap the hoses round as the rear washer motor is still working and source a replacement stalk.
Just before you go daft with a stalk. Peel back the electrical insulation at the pump connector. I have seen the inner wire so badly corroded that it wasn't allowing power through.
Cut back and fix new connectors to the block.
D
