Seicento 1.4 16v
Last problem to resolve is running seicento ECU and shows camshaft sensor fault but runs ok, I know some of you have done this conversion so any advise would be appreciated, has anyone tried a megeasquirt ECU ?
Hi bud, sorry to revive this thread! Any chance you could detail what was involved with this swap? Which ECU/mounts did you use? Any bits need modifying or fabricating? Will it run fine without a piggyback or aftermarket ECU? Many thanks
