Technical Help?
Technical Help?
MannedSage1
Went out in my car today it didn't seem to want to start at first then after a while of trying it started but I was really sluggish and sounded like it had a misfire whenever I slowed down it sounded worse does anyone know what this could be?
It's had a short miss fire before it was like this it only happened after it was standing still so I thought that was the plugs or leads I haven't had a chance to change them yet but could they be the problem or something else?
I think I may have found the problem I've changed the plugs and I checked the leads and i unplugged each lead one by one to check them and two of them wasn't sparking so I'm going to buy some leads and see if that's the solution
coils should be '1 and 4' and '2 and 3', not 1 and 2...are you sure?
D
All the coil packs sparked when I took the leads out. the two on the left I mean the ones that go in engine on the left side they wasn't sparking at all
I've been trying to get the car sorted the miss fire is now gone but the car is still running slow does anyone have any suggestions
It seems like I have lost power I put my foot to the floor and it takes about 15 seconds before the revs start to get near 4000
