Fault occurring when moving suggests more likely to be clutch dragging, or low oil level.
To answer your earlier question, yes, I mean the gearbox oil level.
I'd expect the gearbox to be similar to the Punto. Recently a friend had a gearbox fail on his Punto because the nut on the end of the gearbox shaft had come loose. Sadly found too late to save the box, but you might be lucky if you get the end cover off and check.
