Hi Shaun,Hey,
Water pump is staying on and the old belts going back on seems it looks like new! Like you said get the head done, let the car prove itself then bugger about with other parts. I've had a right game with it tonight.
-How do you get the inlet manifold off the mpi seicento? Do you have to disconnect all the injectors etc?
-How do you get the heat shield off the exhaust to get to the exhaust manifold bolts?
Came very close to calling time on the Sei tonight.
Shaun.
Keep at it. You only learn through trial and error. Continue to use the forum as you are there are loads of blokes(and gals)looking of your shoulder, albeit at a distance.
Once the head is back on (remember clean mating surfaces of old gasket/residue using a 'scraper' but be careful you don't damage the surfaces (block or head) and to 'torque down' in the correct sequence and to correct torque settings/usually in graduations) do change the thermostat and best to 'back flush engine(before refitting thermostat) and radiator. Check all hoses for 'hardness' splits and replace if necessary and also any clamps etc. Clean off all fittings and hose connectors. If you can check radiator for damage to 'vanes' and clean using an airline/soft brush if necessary(airline if you've got all that stuff) and remove any leaves and 'crud'. When you refill mix the coolant and water before pouring in to the correct percentage(not sure for 'Sei') as coolant has rust inhibitors that are essential for preventing internal corrosion and it also increases the boiling point of the cooling system by approx 10%. When topping up the system remember to have the heater on 'hot' and to bleed the system of all air via the 'bleed valves/nipples' in the engine bay. This is done with the engine running after coolant is in the system. You will have to top the system up as you do this, air escaping etc and the heater matrix refilling/purging air etc but maybe not by too much. If your heater then blows cold air when it should be hot whilst driving more than likely means you have an 'air lock' in the hear matrix = re bleed system. Maybe a bit further ahead than you are at the moment but keep at it.
Best
Malcolm
