Hallsy200sx
- Feb 10, 2005
- 56
- 17
Hi, my gf's sei sporting has had a coolant leak for a little while. It looses quite a lot, quite quickly leaving a patch under the car overnight. I got under there and took off the splash guards, etc to see where the leak was coming from. Not much with engine off, but when engine is running there is a constant drip from above the oil filter.
I know the water pump is above this, but is there anything else that could be causing the leak around that area?
The car has done about 50k so could be the water pump failed. If it was leaking though, could it just be the seal to the block?
If it were the water pump, how much should I expect to pay for a pump and cam belt?
