You really ought to do your homework here, the mechanical bits is only a small part of a successful turbo project.
There are ECUs / setups that will deal with very modest boost levels (the ECUs that have a slightly over atmospheric MAP sensor), but I mean like 0.3 bar tops, which is nothing. And even though they'd deal with it, it would be far from optimal and perhaps unsafe. And 1.1 MPI ECUs are not in this class anyhow.
The Novitec setup came with a piggy back controller and/or modified stock ECU, but that was for the SPI setup, MPI is technological ages from that. You are looking at either hooking it up with the DET3 piggyback or an entire aftermarket system. Both solutions should be able to deal with replaced injectors (in case of DET3 by using fuel implant mode and disconnecting them from the factory ECU, which would otherwise freak out).
I am not proposing the third option, as it is not an off the shelf one - I did actually make a turbo version of the 1.1 MPI ECU, but only the big one (not the micro ECU), see here:
https://www.fiatforum.com/cinquecento-seicento/329065-seicento-mpi-turbo-ecu.html
and at posts from roughly a year ago in my thread:
https://www.fiatforum.com/cinquecento-seicento/216652-wojs-turbo-project.html
It was working, but I did not manage to make a stable all purpose map for it, and now the car is gone.
My thread should also tell you about what you look at in terms of engine control and you should really read up on things. Properly done it is a difference between having an all time reliable turbo setup and going bang on the first day
