F Fede92 New member Joined Nov 28, 2015 Messages 1 Points 1 Nov 28, 2015 #1 Hi guys, for a water leak i would replace the water pump. But i have doubt: if i will replace the water pump, Will i need to replace the timing belt?
Duncan Patron member Parked in the garage Joined Feb 12, 2005 Messages 1,269 Points 369 Location Northampton Nov 28, 2015 #2 Yes, the belt will need to come off to get at the water pump and you should not reuse the cambelt. I would also change the tensioner at the same time.
