hi
took me 90 minutes to Put it back
tricks i learnt
1 Paint the bolt heads a bright colour so you can see them
2 run a bight colour around the bolt hole to help you find it
i used a bit of Paint and fingered it around the hole
3 use a cable tie through the 3rd hole to hold the motor in Place to support it while you bolt it up
it takes the weight off of you so all you need to do is Put the bolt in, rather than have to support the weight of the motor while Putting the bolt in
4 gear box side bolt first, from the top, 13mm, not too tight
5 engine side bolt next, nice and tight, then tighten the gear box bolt
6 solenoid lead, 10mm, it had a washer, same light Paint trick
7 that little Power supply lead cover goes on before you attach the Power cable 13 mm, light colour Paint trick
problem is, the engine still does not turn over very quickly, but the motor ran really quickly on the bench:bang:
george
