rolandpeelen
- Dec 10, 2014
- 3
- 1
Hi guys,
Recently brought my cinq in for MOT (dutch one, probably kind of the same). The CO emissions were too high, so they replaced the MAP sensor (I've had some issues with the light coming on in the dash when it was idling). Apparently, it has been running a bit to rich -- Never had any audible idling issues though
All was well, but when I tried driving later the idle was appalling. Just up-and-down and when I revved it, it even stalled a bit later (see video link below). Now, I've never had any issues of this sort, and when I brought it back to the garage, they said they couldn't find any thing and it wasn't their fault. So, :bang:
Anywho, I've tried:
- Replacing the map sensor with the old one (does the same thing, which is quite weird as the garage stated they didn't change anything else)
- Revved the engine while having my finger on the hose at the and of the MAP, it does suck on it (not sure how hard it has to suck, but it does), so I think it's not a vacuum issue
- Pulled out the stationary stepping motor, looked completely clean, cleaned it better anyway
- Checked out the air intake valve, also looks completely clean
- Pulled of Lambda sensor, which does make it run worse (so the sensor does something, although that might just be a false reading)
I'm not an expert by any means but I love to tinkle and I'm not afraid to try anything. Does anybody have some advice? It has become a bit better since then, but it hasn't gone away completely.
Video: https:// youtu .be/MymraVyj-Uc (sorry, only allowed to publish complete links after 5 posts)
Anywho, I've tried:
