Just wondering if anyone has run their cinq or sei on super unleaded? Does it make any difference? My dad used to run it in his cinq
If the ignition timing is correct for 95RON, using 99RON or 102RON can actually reduce power as the burn happens too late.Not really; I've tried both momentum 99 & BP's short lived super 102 in my 899 some years back, but never noticed any difference.
If the ignition timings are correct, all Cinq & Sei should be fine on 95RON Petrol.
My 899 Cinq pinks under full load on 95RON, so I run it on 99RON.
(using 99RON is an easier "fix" than trying to loosen little old screws that will probably snap!)
Little bracket holding the TDC sensor by the crank pulley.Hi what little screws? How do you adjust the timing?
