Help! I have finally run out of ideas so I turn to the assembled know-how of the Forum!
We ahve a 2003 Sei Sporting. The washer has stopped working.
The car is fitted with a single pump with one of those funky valve affairs for front/rear split
The pump runs - I put a battery directly onto it.
The pipe runs are clear.
The electrical coupler has no power to it - I put a bulb onto the spade terminals and no light when I pull the column stick
The fuse is ok and the wipers front and rear work ok.
I am down to the column switch or a break in the wiring somewhere.
Is there something else I can try/check before I start pulling trim panels etc off the car?
Hope there is something obvious and simple that I'm missing!
