A poor earth would cause the lambda sensor (amongst other things) to not be 100% efficient.
Would the stored info of the lambda sensor cause the new one we fitted to not be 100% efficient?
If you have got access to an infra red temp sensor gun thing, try taking the car for a run or you could leave it idle for god knows how long (maybe 1/2 hour) and measure the temperature of the cat before and after.
The temperature should be hotter at the back than the front, so if the temp is less than roughly 75 degrees at the back of the cat it is mostly likely not working efficiently so will need to be replaced and would cause high CO as my cat is rattling (and almost non-existent) and has high CO
Hope this helps
Either you've selected the wrong ECU or there is a bug in their program (they have had this issue with other ECUs in the past...).Ok im a bit baffled by something on multiecuscan. The engine speed doesnt seem to be reading right as its showing the idle rpm of 62880000000rpm ???
Where as on the IAW scan 2 the rpm seems to be right at 943rpm on idle does anyone know what could be the cause of this , many thanks
