right then all you ECU Guru's out there:
Ive heard the 1.1MPI ECU will run a 1.4 16v.
I.e it has a 3 bar fuel pump, knock sensor, coil packs, cam sensor and crank sensor.
I understand the fueling will be an issue so i will use a 1.2 16v ECU and get it mapped in the future.
However just want to see it up and running so not all my funds are going down the drain on it and it will give me the confidence to crack on.
How i want in the future.
1.4 16v engine
MK1 1.2 16v Inlet
1.6 Throttle body (Maybe ITB's in the future)
BMC CDA
SUPERSPRINT exhaust manifold
Cat back exhaust system (any recommendations)
Magnecor leads
Any more advice, tips much appreciated.
Cheers guys!!
1.4 16v engine
MK1 1.2 16v Inlet
BMC CDA
Magnecor leads
Cheers guys!!
