Hi everyone, I wonder if you might be able to give me a hand in getting my cooling fan going. I need to use the car for a long journey and still can't fix this fan.
It has has a new fan (works brilliantly if lead to fan switch has connectors bridged), new fuses, checked relay, new fan switch, new single pin sensor, new temp sensor (inlet manifold) and I have reset the ECU by disconnecting battery. It still won't come on!!!
I did get it to come on by wiggling the fan switch plug once but I have checked that lead and it's not at all corroded or loose (bridge always works perfectly). That's why I changed the switch.
Now the new single pin earthing sensor on the top of the block makes the temp light come on and actually start dim and get brighter as the car gets hotter. What the hell else is there to do? All wiring must work because of bridging and also the fact that the light is consistently brightening (off when cold). The temp light does not come on with ign.
Many thanks,
Sam
Many thanks,
Sam
