car is a cinq sporting.
i have a problem that is progressively getting worse and i am not entirely sure what it is, let me explain:
if the engine is stone cold or has only been stopped for a brief period (still hot) it has no issues.
if i leave the car for 30mins-2hrs or so, i restart the car to go out, it starts fine, drives off fine then for no reason looses power around the 2000rpm area, i slowly increase the revs and then suddenly it will kick in and be ok. this sometimes only happens once, sometime a few times. after it has played up it runs perfect for the duration of the trip.
when this happens i can either ride it out until it decides to work ok again or i can floor it or push the clutch down and blip the throttle and its ok again.
i get no engine lights or ecu error codes come up.
the car has had new plugs, leads, coils, lambda, coolant temp sensor, fuel pump and filter about a year ago. battery is good and i have checked all the ground points i can find.
any ideas?
any ideas?
